Need help with a variable
    Im needing a variable that dont reset when the program is closed . I need this value keep saved to be incremented next time that i use .
How can i do that without use a note pad or something like this ? (cuz i could save in a .txt for example , and read always that i need, but i dont want do that ) .
thx 😃
(3,259 Views)
Hi dunno wha...,
why don't you like to store your value in a file? You can also store values in the registry, but this is not very welcome.
Mike
(3,256 Views)
I don´t want use file cuz havent security .Have some way to put a password in a file using labview 6.0?
(3,252 Views)
Hi dunno wha...,
you can use some Encryption functions, like blowfish.
See also this thread, maybe it helps
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=418732#M418732
Mike
(3,243 Views)
