Need help with an array...
I want to move the first element of a 16-element array to where the second element was, the second to where the third was, and so on, in an incoming infinite data set in LabVIEW. How would I do this? The data is basically a sampled waveform for more context.
Message 1 of 9
(2,885 Views)
Are you creating a circular buffer or moving window of 16 elements in length/size?
Santhosh
Soliton Technologies
Message 2 of 9
(2,878 Views)
Definitely moving window of length. thats exactly what I am trying to do. An infinite set of data in array and first element becomes second element, and 16th element becomes 17th element and so on. So almost like a "moving window" if If you can help on how to achieve this or link some sort of VI that would be amazing.
Message 3 of 9
(2,860 Views)
Each time you receive a new value rotate the array one place and replace element 0 with the new value.
=== Engineer Ambiguously ===
Message 4 of 9
(2,855 Views)
Accepted by topic author Havordpete
Check this out - https://forums.ni.com/t5/Community-Documents/Dynamic-Circular-Buffer/ta-p/4297791
Santhosh
Message 5 of 9
(2,844 Views)
thank you so much for that link, I'm trying to build one of the responses from EMCCI since they didn't add VI to the project but Im having a hard time identifying one of the blocks, I put a image of it below if you could help me out.
Message 6 of 9
(2,829 Views)
Looks like "reshape array". If input and output are both 1D strays, the input gets trimmed or padded with zeroes to the new size
Message 7 of 9
(2,810 Views)
OK, lets clarify a few things. if it is a sampled waveform, it is tagged with a t0 and dt. Do you need to update t0 (Most likely, dt is constant)?
Typically, instead of explaining how (move-move-move) you want do do something, explain what you need to do in a more general way. There are quite a few ptbypt VIs that could do some of the lifting. There is even a data queue ptbypt VI that might be useful.
So please explain the purpose of that history buffer, e.g. process it in some way (Mean, FFT, etc.) or just for cosmetics (display in a graph). The more detail you provide, the more useful our answers will be.
Message 8 of 9
(2,792 Views)
I actually found the solution! Turns out I just needed to implement a “circular shift” but I didn’t know the exact terminology on how to describe it but one of the posters on this page helped out, thank you for your help as well!!
Message 9 of 9
(2,735 Views)
