Need help with arrays
But i havent control about the number of tests ...
The table must show the data in the follow order : (example)
//First test
                                FREQ       AMPL
              M1             2133        323
              M2             345          3213
              M9             123           321
//Second Test
              M1              321           798
              M9              465           45
//N test
Message 11 of 13
(667 Views)
Accepted by topic author faelnpaiva
Back in LabVIEW 6 and 7 the Read From Spreadsheet File was not polymorphic, so you only had the version that read in a text file and returned numbers. However, if you open the VI you will see instructions on the block diagram on how to modify it so you can get strings, which is what you want in this case. It's been a long time since I've programmed in LabVIEW 6. Hadn't realized how much I'm so used to the automatic tool selection! Smiley Very Happy
Try the attached mod as a starting point.
Message 12 of 13
(658 Views)
Ty very much 😃
Message 13 of 13
(656 Views)
