Need help with configuring the "trig" port on a PXIe-8862 controller to output a 1 Hz signal.
Need help with configuring the "trig" port on a PXIe-8862 controller to output a 1 Hz signal. The LabView version is 2019 and the chassis is a PXIe-1092
(582 Views)
Accepted by topic author micgraph
The trig port on the PXI controller can only import but not export signal. You would need a module to export a PPS signal. Most of the DAQ modules can do that.
https://tmesystems.net/
(504 Views)
