Need help with interfacing HC-SR04 Ultrasonic Range Sensor with NI SCB-68/PCI 6251
I am fairly new to LabVIEW and i need help with connecting and building a VI for the HC-SR04 range sensor. I have access to NI SCB 68 connector block along with PCI 6251 using LabVIEW 2014. The HC-SR04 will be used to measure the amplitude of vibration(displacement) of a spring-mass system.
I have come across this topic where they have used SensorDAQ Vernier to connect the HC-SR04 to.
https://forums.ni.com/t5/LabVIEW/help-in-the-programming-of-the-Hc-sr04-ultrasonic-sensor/td-p/1971669
Any help will be much appreciated!
Message 1 of 1
(2,519 Views)
