Need help with problem using sound and vibration examples. question repost
I am generating a wav file using the sound and vibration example vi "SVXMPL_Wav Recorder(DAQmx)" using a ni 7422 board.  Then, using the example vi SVXMPL_Getting started with SVT(Simulated)" attempting to play back that file.  the wav file will load and play back on the graphs fine but when I click the "Play Wav File" which sends the audio to the computers speaker,  I get the error "Cannot recognise sound Format".  It plays the shipped example files fine.  I can also play the wav files I generate on a Windows audio player.  Don't know a lot about the sound and vibration toolkit or wav file formats but need to get these two to work together.  Using LV 8.5 and sound and vibration toolkit 4.0.  This is a bit of a repost of the same question ask last week but not answered.  Thanks
(2,725 Views)
Please be patient. Your question will be answered. Please stick to the same thread. It will just be confusing If you multipost the same thing.
(2,724 Views)
Sorry to confuse the situation.  Seems the error message is generated in the Call Library Function Node in the "Play Sound File" subroutine.  Using windows XP
(2,716 Views)
Did you see Coq Rouge's reply in your original thread? Which thread are you going to continue?
(2,697 Views)
