Need help with the Call Llibrary Function Node when a DLL returns a pointer to data buffer.
Hello, could you please post the VI?
I got a message in the front pannel on the SSI activex reference wich says Control could not be loaded.
Message 21 of 23
(676 Views)
Sorry, i have solved the control not found, i was working on a computer that did'n had the activex control installed.
Now the scanner does not retreive data. scanner model is MS954.
Does anybody know if i have to configure someway the scanner?
I will try during this weekend to build a C# app for this to comunicate via text file.
Thanks in advance for any help.
Message 22 of 23
(667 Views)
here you go!!
don't forget mark as solved.
Saludos
Message 23 of 23
(636 Views)
