Need help with while loop and shift registers
I have a large data set and need to read in the data at maybe 200 samples at a time, process these samples through my VI, and have it append and concatenate a separate lvm file.  The part where I am confused is the shift registers. How do I limit the number of samples read in an iteration? How do I get the while loop to stop when all the data are read in?
I've attached my diagram, maybe there is something wrong with my technique?
(2,670 Views)
Accepted by topic author Evilduck
This will give you an idea.  There are plenty of other (probably more efficient) methods.  This is a basic, quick and dirty solution to help you grasp the overall concept.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,649 Views)
