Need immediate help please!
I have several lab pc's running LV's runtime engine. The OS is XP Professional. I have upgraded from LV 7.0 to 7.1. See the attached gif to see what software is installed. I am the administrator for the pc's. When I log on the program works fine, when a lab tech logs on he gets multiple errors dealing with DAQ vi's. See the attached gif for the list of errors. Now under LV 7.0 and its associated drivers (eg., DAQ 7.1) the program worked without error for the techs. Now that all the drivers have been upgraded for LV 7.1, an error occurs for the techs (non administrator rights). So it appears to be a privilege problem, but I don't understand what?
Any suggestions are most appreciated. Thank you. Also, setting everyone t
o adminstrative privileges is not an option since all our techs are not computer savvy.
(2,666 Views)
I was able to come across a similar discussion forum posting that I think you should take a look at. http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=50650000000800000029380000&ECategory=LabVIEW.LabVIEW+General. It appears that the solution to this problem is to give users "read", "write", "exectute", and "list" rights for the "C:\Program Files\National Instruments" directory. Post back to this forum if this doesn't work out for you.
Jared A.
(2,666 Views)
