Need info on a DAQ or I/O cards.
I need help with a DAQ card that will obtain measurements needed in a windtunnel. It needs to read pressure and strain tranducer, Control stepper motors for a sting and traverser.
(2,518 Views)
I would suggest contacting your local NI Field Engineer for something like this. The hardware you will require depends upon the speed of acquisition you need, how many lines, etc. They can help you just as well or better than anyone else because they even come out to your site to see your application. Call NI at 512.683.0100 and tell them you want to contact your local Field Engineer and they can help you out.
J.R. Allen
(2,518 Views)
