Need multiplt file select in LabVIEW 6.1
I would like to select multiplt files at a time using shift key. I upgraded to LabVIEW 6.1 this feature is not available.
(2,541 Views)
Troy,
Please try the following Example program as a solution. Right now, we use the standard Windows file dialog box, but we only ever use it when getting just one file. To have multiple files, one needs to create a VI that does this. That is what the example does.
Randy Hoskin
Applications Engineer
http://www.ni.com/ask
(2,541 Views)
