Need some help with stopping a pulse
Hi, so me and my friend had just made this project:
How it works is like this:
When the input DAQ's voltage is 3.7, it will trigger the output DAQ(vibrator), which will make the vibrator pulse.
But the problem me and my friend is having is this:
For the pulse to work, it needs to be in the while loop. But since its in the while loop, it will never stop, even after the voltage has dropped below 3.7v.
Is there any way to stop/reset the pulsing?
Thank you in advance.
Message 1 of 9
(3,413 Views)
Read the DAQ data inside the loop, and if < 3.7, stop the loop, the same way you fired the case statement. Or set up a parallel loop to read DAQ data and use local variables or Notifiers to read the data in the other loop.
Also, you don't need the sequence structure, the express VI's have error in/out for sequencing.
Message Edited by Broken Arrow on 08-06-2008 10:25 AM
Richard
Message 2 of 9
(3,404 Views)
How do you use the error in/out function to generate a pulse?
(I'm kind of new to labview)
Message 3 of 9
(3,396 Views)
No, that was a different subject.. I was just saying you can wire the error clusters rather than using the sequence structure. This will also help straighten out your code so we can see it better.
Message Edited by Broken Arrow on 08-06-2008 10:40 AM
Richard
Message 4 of 9
(3,394 Views)
So, to make it stop, I must get rid of the case structure and directly wire the ">=" comparator to the while loop?
Message 5 of 9
(3,380 Views)
Smiley Wink..........Not exactly.... if you'll post the actual VI, I'll write you a solution
Richard
Message 6 of 9
(3,367 Views)
Ah darn it... the actual vi is at school and I'm at home currently.
Can you describe roughly what I should add/do?
Message 7 of 9
(3,362 Views)
This is FAR from ideal... I did it in MS Paint Smiley Surprised because I don't have a DAQ device setup to make the express VI, and I'm too lazy to simulate one, but this is what I mean... If you want to stop the loop predicated on something that the DAQ sees, you have to read the DAQ inside the loop... or do a parallel process (better) but this'll probably work. It'll stop after (or before) the pulse when DAQ drops below 3.7.
Richard
Message 8 of 9
(3,358 Views)
I'll try it tomorrow when I get to school.
Thanks for the help Smiley Very Happy
Message 9 of 9
(3,353 Views)
