Need to Implement Reverse Address Resolution Protocol (RARP) Server in a Real-Time (RT) PXI System
@Nick014 wrote:
The client needs to see an RARP message in response with the its IP address. It does not support the DCHP protocol.
I didn't tell you to use the DHCP protocol.  I just told you to set each of the equipment to a static IP address and set the DHCP server to reserve those addresses so it doesn't give them to anyone else.
But are you saying that there is no way to set the equipment to static IP?  You have to use RARP?
Bill
CLD
(Mid-Level minion.)
Message 11 of 11
(758 Views)
