Need to Print Screen the Front Panel
Hey guys, as the subject says, I need to capture the front panel of the Vi every time it runs (without using alt-printscreen or any other applications). Can I do this using LabVIEW 8? Thanks!
Message 1 of 8
(4,914 Views)
There is a tool available on the forum that will be useful to document your vi.  It should work for the Front Panel.
Let me look for the link.
RayR
Message 2 of 8
(4,913 Views)
Here is the link to the Code Capture Tool: http://forums.ni.com/ni/board/message?board.id=170&thread.id=304756
Within the link, there is a demo and discussion on how to use it.
The code is also available for download.
RayR
Message 3 of 8
(4,909 Views)
Thanks for the fast response!
That tool looks very useful but I cannot download or install anything on this computer (lab computer, not mine so no permission and I have to use this computer) so I have to use what's available in LabVIEW 8. Do you have an alternative solution?
Message 4 of 8
(4,907 Views)
Have a look at this thread which provides a small coding example.
http://forums.ni.com/ni/board/message?board.id=170&message.id=236001
The example shows how to save the front panel as a jpeg image.
RayR
Message 5 of 8
(4,892 Views)
Here's a code example.
RayR
Message 6 of 8
(4,888 Views)
Got it! Thank you so much for your help!!
Message 7 of 8
(4,884 Views)
You're welcomed.. Glad to help.
RayR
Message 8 of 8
(4,866 Views)
