Need to be Able to use a TB-1328 with an SCXI-1125
I need some labview code to show me how to read temp from a SCXI-1125 with a TB-1328 thermocouple on it. I have a K type thermocouple wire, I have to stick with Labview V7.0, NI-DAQ 6.9.3f5, and this is running on an RT machine using a PXI-1010 split PXI/SCXI chassis, with a PXI-6040E running the SCXI bus. Please if you could, tell me how to remote DAQ configure this. Thank you.
(2,385 Views)
If you have NI-DAQ 6.9.3 support installed for LabVIEW 7.0, then you should have an example which will show you how to acquire a thermocouple reading from a SCXI-1125. The example which I am referring to is called "SCXI-1125 Thermocouple.vi". Regardless of what terminal block you are using with the SCXI-1125, you need to make sure that you configure it accordingly in Measurement and Automation Explorer.
For assistance with Remote DAQ configurations, please refer to the following knoweldgebase: What Do I Need to Know to Set Up My Remote SCXI System?
Jared A
(2,385 Views)
