Need to change from a True/False to a O or 1 output.
Need to change from a True/False to a O or 1 output. I have a grahical switch which is giving me a True/false output. I need a 0 or 1 output.
Ed
Message 1 of 8
(7,679 Views)
Have you tried the Help? Or you can also search the functions palette. Boolean to 0,1.
Message 2 of 8
(7,676 Views)
Accepted by topic author Edis Here
Take a peek inside the Boolean palette on the block diagram.
Message 3 of 8
(7,674 Views)
On the boolean palette you will find the Boolean to 0,1 function:
     Rob
Message 4 of 8
(7,670 Views)
I'm amused over the fact that Darin simply gave him a hint, while I explicitly gave a link saying which function to use, but Darin got the solution.
I suspect he didn't like the fact that I chided him for not using the tools available to him, like the Help and search.  Smiley Very Happy
Message 5 of 8
(7,664 Views)
Or the fact that Darin just types faster than we do?
Getting a solution is what matters anyway and we were all in agreement on the solution.
     Rob
Message 6 of 8
(7,662 Views)
He could have thanked us for the help and then marked that message as the solution.  Smiley Tongue
Message 7 of 8
(7,650 Views)
Actually, if you'll note, mine was posted one minute before Darin's.  Smiley Wink
Quite true.
Message 8 of 8
(7,625 Views)
