Need to convert a 2D array into two 1D arrays to be fed into Build XY Graph
Hi Need to convert the 2D Output of a sub vI for display on XY Graph. Help!!! I cant find an array function that takes a 2D input and un-builds to 2 * 1D arrays
(3,125 Views)
Hi dht,
try the array function "Indicate Array" with only one index input connected.
Stephan
(3,125 Views)
thanks stephan.
I used index array which I guess is what you meant?
dave
(3,125 Views)
Hi Dave,
if it is working than that's it.
I'm using the german version of LabView and it is sometimes difficult to translate the names 😉
Stephan
(3,125 Views)
