Need to convert from 3.0 to 6.0.2 and smoothing
I want to try these smoothing VIs but cannot open due to version number. I am building a data aquistion system using field point and want to smooth the data. I have been doing a running average but still need better results. Any comments would be appreciated.
MIKE
(2,756 Views)
Look here. It seems like this question comes up a lot. Have you tried searching through previous posts?
(2,756 Views)
I didn't know about that utility. You have to order the software becasue it is not available for download. Unfortunately I need this done as soon as possible. So if someone could convert these for me that would rock...
(2,756 Views)
Here they are. It was easier to convert with the files removed from the library.
You were in luck. I just received the conversion CD about a week ago. Hope this helps.
-Kevin
(2,756 Views)
