Need to create text file as my memory .
hi
Message 11 of 16
(1,064 Views)
Same thing, just multiply the location by 8 to get the nth element and adjust the various diagram constants for the correct values and representation as appropriate.
Message 12 of 16
(1,056 Views)
Message 13 of 16
(1,055 Views)
Message 14 of 16
(1,045 Views)
@SaranVenkateshS wrote:
  tried this Can you check this
Why can't you check it yourself? You would immediately see that if does not work correctly.
You need to make the file 8x larger, you need an 8bit stride for each element, and you need to read it as DBL type.
See attached....
Message 15 of 16
(1,033 Views)
Thanks a lot ..
Message 16 of 16
(1,026 Views)
