Need to edit VI inside a Labview Executable File
I have the student version of the labView. Is there a way to edit the origial VI file inside a Labview Executable file ?
Please see attached picture for detail.
Many thanks
ffl3883
(3,395 Views)
No, you can't edit the VI. The block diagram is removed during the build process. Any don't you have the source code?
(3,381 Views)
Thank you for your reply. I lost the source code data... Unfortunately.
(3,370 Views)
