Need to find a driver for cRIO-9211 thermocouple to be used with LabView
I am using the NI cRIO-9211 Thermocouple input and the NI USB-9162 Hi-Speed USB Carrier and need to find a driver to interface the thermocouple with LabView 8.5.1. Could you point me in the right direction as to where I can download a driver for this?
(2,770 Views)
Hi Durnan,
You will require the DAQmx driver for the USB 9162. This can be found here: ni.com/downloads, see DAQmx 8.8 - would do.
You only require the DAQmx driver, as the C Series modules are supported - they can just be used in a cRIO as well.
Hope this helps,
Kind Regards,
James.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,759 Views)
