Need to flip a switch and have a tank fill until full at const rate?
I need a tank indicator to start at zero and fill to it's max at a constant rate. It seems like there should be some function for that or should I just put it in a while loop and feed the output to the tank?
(2,735 Views)
I think this should fulfil your requirements and then you can add stuff, like conditions,value,etc the way you want it.
(2,735 Views)
you just need to write into this indicator the new value in the while loop til the moment when it exceeds the max.
Here is the example.
Good luck.
Oleg Chutko.
(2,735 Views)
