Need to index an array.
Hello Everyone,
I have been looking for a solution to my problem but I haven't found one yet. I am testing a piece of magnetic tape for friction properties. I am using a machine to pull a piece of tape back and forth across a static guide for 8 loops. I then take the max value of the 1st and 8th loops to make judgement. I am using a usb-6009 to acquire the voltage from the load cell and I want to index each loop so I can use the array max and min to find my data points. Is there any way to index each loop using the forward motor direction voltage as my index point. The motor drive has 5v DC in the forward and 0v in reverse. I am using LV 7.1 with Win2K. Thanks for your time and sorry this is so long.
Brett
(3,033 Views)
It is very unclear to me what you actually want to do. I suggest you post your code (properly commented) so we can understand what's going on.
___________________
Try to take over the world!
(3,008 Views)
