Need to locate a control as absolute coordinates?
Is there a mean to locate a control as absolute position (screen coordinates) with interface containing splitter(s)?
I wrote a solution but not very smart and not optimised:
I used this method because I encounter a problem with a shadow offset of each splitter origin. And so, I can't sum the object position and the pane position to obtain the absolute position.
Better soluce?
I work on an application developed in LV8.5.1.
Message Edité par J.DECHET le 07-20-2009 01:07 PM
(3,084 Views)
What do you want to do?
Find the location of 1 control referenced to the display borders, not the VI borders, is that it?
Additional problem, the VI contain splitter(s) 😞
Biggest problem is that you don't know in which splitted part of the front panel to control is located 😞
Strange that I don't see any reference to the possible splitter(s) in your code.
With the attached code you get the position of the "numeric" control reference to both VI & screen.
Works fine when no splitters are used Smiley Tongue
(3,070 Views)
Biggest problem is that you don't know in which splitted part of the front panel to control is located :smileysad: => This is exactly my problem!!!
Strange that I don't see any reference to the possible splitter(s) in your code. => Splitter are just separation of "panes" but as origin of splitters is wrong (because an undefined offset) I can't used it. That's why, I use panes instead of splitters.
Thanks for your code but my interfaces are specifically made with splitters.
To redefine my question : how to know the most efficiently possible in which pane is an object?
In fact, I need this function 2 times in my application:
- to operate a snapshot of an interface and to highlight some specific controls.
- to operate a left click on combo box to avoid the User to click 2 times (one for focus, the other to obatin the menu)
Message Edité par J.DECHET le 07-20-2009 02:09 PM
(3,064 Views)
