Need to pick an easy tool to develope an automation testbed
I'm thinking of using Labview to develop an automation testbed to validate a newly system design. I would need all the helps out there such as:
1/ what do I need in order to design/control and vary 3 HP power supplies and temperature of a thermal chamber. All with GPIB interface.
2/ To execute some system command line interface (CLI) and to capture some sort of warning and error from system console.
Thank you,
--tony
(2,625 Views)
"edvt" wrote in message
news:50650000000800000076D30000-1079395200000@exchange.ni.com...
> such as:
LabVIEW would be great for this. But remember LabVIEW is a programming
language, not a tool. It sounds to me like teststand (NI) is worth a look
(combined with LabVIEW). If it seems to fit, ask for a demo from your local
NI office. Teststand is a "sequencer", and if you need to sequence tests you
can save the time to make this in LabVIEW.
> interface.
You need a GPIB card. NI has th
em. You also need LabVIEW drivers, or you
need to make them yourself (then you need the manual). The NI website and
the HP/Agilent website would be good to start looking. If you cannot find
them, you can always post another question in the newsgroup.
Exectuing CLI's is standard possible in LabVIEW (System Exec), and I think
it is also standard in teststand. Capturing text from a system console might
be more difficult, but if it can be done in e.g. c it can be done in
LabVIEW.
> Thank you,
> --tony
Wiebe.
(2,624 Views)
Did you mean HP as in high power or Hewlet Packert? Search the www for "high
power supply gpib" and you'll find http://www.kepcopower.com/bophi.htm .
Temperature control often use serial interfaces, but
http://www.testequity.net/products/1104 has GPIB as option. (Search for
"temperature control chamber gpib".)
Wiebe.
"Wiebe@CARYA" wrote in message
news:40a088bb@newsgroups....
> Hi,
> > such as:
ramming
local
you
> > interface.
> You need a GPIB card. NI has them. You also need LabVIEW drivers, or you
console
might
> LabVIEW.
> > Thank you,
> > --tony
> Regards,
> Wiebe.
(2,624 Views)
