Need to recorde voltage data after every 10 minutes
Hi, Can you please have a look at my code? I'm getting voltage data for every seconds but I need it for after every 10 minutes and I will record the data.
what I should do??
Message 1 of 12
(3,540 Views)
i never use the assistant vis, so im not sure,
but it looks to me that you get 100 samples at a 1 sample per 1/100s, then the loop iteration restarts,
to have this every 10min you would have to put a wait at the end.
make sure the data flow is proper since the "wait (ms)" vi has only a numeric input, you want to have the loop wait as the last action, before next iteration starts
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 12
(3,511 Views)
Long waits are generally a bad idea.  You could instead use the Elapsed Time function set for 10 minutes and put your logging code in a case structure.
GCentral
Message 3 of 12
(3,507 Views)
I tried to do this..it didn't work. Can you please help me to do that?
Message 4 of 12
(3,482 Views)
I also used elapsed time.Can you please help me to do that?
Message 5 of 12
(3,480 Views)
Crossrulz's instructions were pretty simple and straight forward.  If you didn't get it, attach your VI so we can see where you went wrong.
Message 6 of 12
(3,465 Views)
Hi..thanks for your reply. attached is my code. I'm stuck at here.
Message 7 of 12
(3,460 Views)
That is a completely different VI!
Message 8 of 12
(3,456 Views)
Hi Riad, try something like this:
Message 9 of 12
(3,443 Views)
Hi....tried it ....couldn't get it,. Can you please do it in my code? Then I can understand better.
Message 10 of 12
(3,434 Views)
