Need to terminate with <null> when writing to GPIB
I'm trying to write a program to communicate with my spectrometer. It seems I need to terminate a certain command with a <null> character. I've tried concatenating an empty string constant but still does not work. I'm more familiar with the C programming method where you append a "\00", which designates the <null> character, after the command. Any help would be appreciated and thanks in advance.
(2,582 Views)
Accepted by topic author sdkpark
Instead of an empty string, concatenate a string diagram constant containing the null character. (Right-click the constant and select \-codes display, then enter \00, or select hex display and enter 00)
(2,579 Views)
Thank you very much. I will try it tomorrow and let you know how it goes!
(2,576 Views)
