Need urgent help controlling led matrix 7219
I have been trying to control a led matrix with max7219 for a class project but i cant get it to work. I am pretty new to labview and arduino so I really confused at what i am doing wrong. The first three states are to initialize the led matrix, the 4th case does nothing while the 5th case inputs a 16bit binary code. It seems that for display test and shutdown mode works fine but when i try a digit mode to utilize the matrix in normal mode nothing happens. If someone can point out what i am doing wrong it would be of so much help. I attach my VI as well as some data from data sheets. I suspect I also am using wrong the function 'spi write by n frames'. I have been trying a number of different things but i cant figure out where the fault is.
TheMartin_0-1637255927614.pngTheMartin_1-1637255941101.pngTheMartin_2-1637255978468.png
I am using an Arduino Uno and led matrix max7219. I dont get any error code, but i dont get the output wanted in the matrix.
(1,718 Views)
Accepted by topic author TheMartin
Hello  TheMartin
- If the first three states are for "initialization":
  • Why do you start the state machine in the number 4?
- What is the "boolean" button for?
- You are only going through numbers 4 and 5 states, the code never goes to the 0, 1, 2 and 3 states numbers because you are starting at 4.
In addition, where you are building the array, you are doing this:
As you can see, this is not what you need for writing into the SPI function.
Staff Technical Support Engineer
(1,677 Views)
Thank you very much, indeed the initialization was the problem. I know the structure is a mess, but changing the initialization to 0 instead of 4 worked. Sorry for such a rookie mistake. I just got such an immense relief. Thank you very much.
(1,637 Views)
Hello TheMartin,
That's great!
You're welcome, good luck.
(1,633 Views)
hey, can u help me? im trying to control the matrix 7219 using labview with myrio as controller, i don't know where to start, do u have any reference?
(719 Views)
