Need urgent help to use or modify the "ultrasonic starter kit"
Hi, I am a french student, and I am working on an ultrasonic table with Labview 7.1.
On the one hand, I have done the control of the table that moves the "probe?", and on the other hand I have done the program that read the picture given by EPOCH (an ultrasonic system that detects interfaces into metals).
So, now my goal is now to mix them to make a map of those interfaces (one gives the position (x,y) of the probe and the other a graph with intensity peaks).
I have found the "ultrasonic starter kit", and I would like to modify it, but I need help to remove the part that simulates the graph of intensity in order to replace it with mine and to remove the part that simulates (x,y) position to replace it by my positions that are controled in the same order. (y decreases each time x>constant).
In case you would like to help me and need my work or a better description, please contact me to : fx.mayaud@gmail.com.
François-Xavier MAYAUD.
Thank you.
(2,695 Views)
Salut,
Peux tu préciser un peu ta question ?
ClémentG
(2,682 Views)
I think it would be easier for you to start from a blank VI, than modifiying the example you found which is quite complex. Try to use an intensity graph with inputs as your data.
ClémentG
(2,646 Views)
