Need urgent help with Error -200018
hi norbert,
We have here another host PC, but I think it has about the similar specification. I've tried to contact NI per phone, but they are always busy, I dont get any support from telephone. And my supervisor keeps pushing me to call them as much as possible (but I just get the machine).Well, any NI technician is online at the moment in this forum?
regards,
Yan.
Message 21 of 25
(874 Views)
hi norbert,
I've just read about other buffer underflow error here, and want to ask you about using onboard buffer to output my signal. Any example for this in web?
regards,
yan.
Message 22 of 25
(860 Views)
hi norbert,
I've tried to call few times already to get support about this problem. And Mr. Spitzer (support techniker of NI Germany) has told me that possibly my PC is not fast enough to make this works. He said he would like to find out about this and confirm to me if its really PC spec problem or no. Can you please confirm this again with him, because my supervisor is starting to lose his patient about this.
regards,
yan.
Message 23 of 25
(833 Views)
As for DAQmx: Continuous buffered generation: https://decibel.ni.com/content/docs/DOC-15893 the Problem occurs durring the Transfer over the DMA oft the PCI.
Unfortunately when you said that everything works aslong as you dont run the Scope VI, that made the guess for the limited Buffer obsolete.
Chasis: NI-PXIe 1082
SLOT 1: Controller: NI-PXIe 8370 verbunden mit MXI-express X4 Kabel (3-meter), verbunden mit PCI slot 4 (mein PC ist DELL Optiplex 990, service tag: 3B7K65J)
SLOT 2: -frei-
SLOT 3: NI -PXIe 6544 (100MHz Digital I/O)
SLOT 4: NI-PXIe 6674T (Timing Module)
SLOT 5: -frei-
SLOT 6: -frei-
SLOT 7: NI-PXI 6733 (16Bit Analog Output)
SLOT 8: NI-PXI 5105 (12Bit 60MS/s Digitizer)
NI 6733: http://sine.ni.com/ds/app/doc/p/id/ds-158/lang/en
Max update rate
Number of ChannelsMax Update Rate
Using Local FIFO (kS/s) 1Using Host PC Memory (kS/s) 2
1 1,000 1,000
2 1,000 1,000
3 1,000 1,000
4 1,000 1,000
5 1,000 1,000
6 952 1,000
7 833 869
8 740 769
Type of DAC
  Double-buffered, multiplying
FIFO buffer size
NI 6731
  8,192 samples
NI 6733
  16,384 samples
DMA channels
  3
Data transfers
  DMA, interrupts, programmed I/O
DMA modes
  Scatter-gather
Since you ran the test with 8 Chans and 1MS/s sucessfully, i don't suppose that that table is the problem.
Alexander P.
NIG AE
NIE SRQ:1226512
Message 24 of 25
(818 Views)
Hi Alex,
thanks for clarification. But now, how can I generate and acquire the desired waveform with sample rate 1MHz? hardware exchange?
regards,
Yan.
Message 25 of 25
(799 Views)
