Need versatile way to pass data to graph
I have a sub-vi that does some data analysis. I output the results through a type def. I want this type def to include the data needed to plot the results in a XY-graph.
My problem is that the data will sometimes contain only 1 data series and sometimes multiple ones. i.e. sometimes the output should be a cluster of two 1D-arrays, sometimes it should be an array of clusters. Is there a good way to achieve this?
vs
(3,371 Views)
Since the conversation has actually started in the other thread, please continue over there: http://forums.ni.com/t5/LabVIEW/Need-versatile-way-to-pass-data-to-graph/m-p/3335871#U3335871
(3,361 Views)
