Needed Hardware for 1PPS and analog Waveform
Hi .
Im looking for 2 boards or maybe one that supports the both requierments.
1. I need to implement a 1PPS signal (while the '1' is 8-10VDC).
2. Output 2 waveforms of amplitude up to 7 VDC , with phase shift of 45.
I thought to implement a code using felxrio and labview but dont know which hardware to use.
Thank you.
(2,122 Views)
Accepted by topic author Cobmetal
Hi Cobmetal,
as you didn't supply most of your requirements I suggest to use a simple USB6002 with an amplifier (like a MOSFET) for its DO pins…
(2,116 Views)
