Negative SNR
hello all
i have a problem
i have a ECG signal that it's without noise . but when i want to measure SNR ( signal to noise ratio ) i see negative number like -5 or -6 ........
a negative number for snr mean which noise signal is greater than ECG signal but my signal is without noise .
please help me
i attached my file
Message 1 of 8
(6,025 Views)
I do not have the SVT VIs.
Are some of the high frequency components of the ECG waveform being included in the noise part of the calculation?
Lynn
Message 2 of 8
(6,010 Views)
i don't know exactly
i sent another circuit for SNR calculation .
the result of  both of them are the same
Message 3 of 8
(6,001 Views)
I do not have some of the subVIs for the Simulate ECG VI. Please create an indicator on the output of Simulate ECG.vi. Run the VI. Then Edit >> Make Current Values Default. Save the VI again. Post that VI.  It will have the data in the indicator and then I can look at what is going on.
Lynn
Message 4 of 8
(5,997 Views)
All this seems to be part of the biomedical toolkit. I don't have it either.
Message 5 of 8
(5,995 Views)
i done
Message 6 of 8
(5,963 Views)
Wish I could open the VI.  😞  You sure you haven't swapped signal and noise in your calucaltion?
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(5,924 Views)
You probably did not want the reciprical of a logrithmic ratioSmiley Surprised  that just doesn't wook too well
Message 8 of 8
(5,915 Views)
