I have a problem with my waveform graph : I would like to set Y negative scale in a logarithmic mode. How can I do that? It seems to be impossible (always set to '0' if a set negative value)! What is the problem ? Thank's in advance.
The reason is simple, logarithmic values cannot be negative, as logarithm is asintothic in zero, this means log 0 has a value of -inf. So what you want is impossible.
I mean that if you set y axis scale as logaritmic, you can't put negative values, it will allways have a zero as start as long as it can't be beyond that.
> I have a problem with my waveform graph : I would like to set Y > negative scale in a logarithmic mode. How can I do that? It seems to > be impossible (always set to '0' if a set negative value)! What is the > problem ? > Thank's in advance.
