Neo Vi vs MAX
Hi all.
I want read the Neo VI Fire in the Max Software, what I need do?
(3,424 Views)
Please continue in your other related post.  Also, in that thread, you still did not explain what "Neo VI Fire" means.  If it is a VI, where did you get it from?
(3,400 Views)
Kallman, since the neoVI is not an NI product, you will not be able to access it from MAX .You'll need to use the utilities/configuration software from Intrepid for that.
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(3,374 Views)
