Nested For Loop skipping case structure
OP is Original Poster
Quotient and remainder is on the numeric palette Q is not necessary Remainder (of iteration) will increment from 0 (Iteration is evenly divisable by divisor) to divisor - 1
I.e..
For i- remainder  for divisor = 4
i    r
0   0
1   1
2   2
3   3
4   0
5   1
6    2
7    3
8    0
Message 11 of 13
(965 Views)
Jeff,
the hardware is a signal generator, an agilent switch driver, and a power meter.
Message 12 of 13
(964 Views)
Thank you all for your help. After much testing I found that playing with Time Delays between all the subVI's did the trick.
Message 13 of 13
(934 Views)
