Nested Right Click Menus
Hi Team,
I feel like this must have been asked before but I can't find any information about it... Please link to an existing thread if this is a duplicate.
How can we make nested right-click menus like in the image below?
I assumed it would be like the project provider where you just add a backslash in the menu name, but this doesn't seem to work.
Example of how it's done with project providers. Doesn't work with RCMs?
(3,679 Views)
You can find an example here. The "Create Event" plugin menu uses submenu's.
But it is not as straight forward as what you describe.
Best Regards,
Stefan Lemmens
Intersoft Electronics
(4,099 Views)
Cheers, Stefan! using that example I was able to really quickly make a PoC
Although not as straight forward as I thought, it's still really do-able 🙂
(4,087 Views)
Hi McQuillan,
have you tried to create a RTM file with the menu editor available in the LabVIEW IDE? ("Edit" menu -> "Run-Time menu")
There you can use 4 arrow buttons to order menu items…
(3,673 Views)
