Nested State machine - Loops continuously
Hello ,
I implemented a program for first time using state machines and Enum (type def).
I have 2 state machines (nested)
I am not sure if the data flow between the Main state machine and the Sub state machine is correct. The program loops continuously ( this is a MOTOR PROGRAM) and I see that the motor keeps working continuously. It is supposed to run the mentioned Number of Steps once and then stop.
Please have a look at my code and tell me where I could have gone wrong.
Thank you.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(3,604 Views)
Figured out ! Thank you. One of the ENUM was not defined to the correct state.
Thank you.
Abhilash S Nair
LabView Gear:
(3,555 Views)
