Nested for loop
Dear ,
I would like to build an array of 8192 value which comes from sweeping a 13 bit DAC.
The outer loop will iterate from 0 to 31 (5 bit) and the inner loop from 0 to 255.
So for every outer for loop I will need to add code from inner loop untill I reach 8192 value.
every code from 0 to 8192 will be place in the 8 bit array any idea how to build such a fuction?
(2,576 Views)
Hi malkowski,
For storing data of a 13 bit DAC you cannot use an "8 bit array"!
Why do you need an outer and an inner loop to handle 8192 array elements?
What have you tried and where are you stuck?
(2,552 Views)
HiGerdW,
I did express myself correctly I guess,
Here is not a matter of where to store data but to sweep digital code from 0 to 8191 to an internal Digital block which does the job inside a CHIP.
Data must be stored in two different 8 bit register then concatenate internally then sent the DAC block unit.
So I will need to use a nested loop where the MSB part is a 5bit string Nloop=32 then inner loop N=255.
So for every Nouter loop I need to sweep 255 bit, at the end I will get 8192 swept code to the DAC block.
(2,491 Views)
Not sure what you want exactly, but it sounds like a complicated way to do it.
(2,485 Views)
