.Net Assembly debugging
If I receive a .NET assembly and it doesn't work in LabVIEW, how do I debugg the assembly?  I just want to debug the assembly to an extend that I can tell the assembly developer what need to be fixed.
Kudos and Accepted as Solution are welcome!
(3,013 Views)
Accepted by topic author jyang72211
Did you try a search?
http://digital.ni.com/public.nsf/allkb/6229347C7982CC81862576E30076A4AE
This only works if you have the source, but you can generate this if it is not obfuscated from a decompiler tool. Other IDEs that can host a debug a .net process are probably capable of this too if you don't have VS Professional.
(3,005 Views)
I actually found the same link after I posted the question.  Thanks!
(2,983 Views)
