.Net Dll
Hello ,
In the application the .Net2.0 Dll is called from the Lavciew 7.1 Vi
When the .Net Dll path is selected in the construct of the  VI , saved and close the vi run the dll and provide the result.
 If the Labview software is closed and opened again and run the same vi, we can observe that the construct path is changed to default.
 Please guide home to save the .Netdll path in construct  so that it will not change to default.
(2,780 Views)
If you are running LabVIEW 7.1 you will need to get the update to 7.1.1f2 before trying anything related to .NET 2.0.
(2,773 Views)
