.Net referencing classes in other assemblies = Broken (Error Report)
Just wanted to report this error:
If you define a class in one assembly, then reference it with a generic parameter in another, labview will not be able to find that class.
e.g:
assembly1:
define Class1
assembly2: using assembly1
assembly2 now employs a generic like a List<type> on Class1 from assembly 1
e.g. List<Class1>
-> LV won't find that reference, always EOF Error4 'not found'.
It's a rather exotic big but a definite one so i thought i inform you about that. I tried to make this work for a couple of hours until i figured it's 100% a shortcoming on LV's end.
P.S.: It works of course if you define the Class in Assembly2 OR if you just reference the general Class but as soon as you combine "class from referenced assembly + generic" is fails.
Message 1 of 1
(2,184 Views)
