Netowork Stream Error Code
Hi Everyone,
I have an issue running an RT program on my cRIO 9012. I have been network streaming information from the rio to the computer for a while now, however I had to restart my computer and I am now getting an Error code coming out of the "Create Network Stream Writer Endpoint". The error is -314000. " Labview cannot load the ni_nwstreams library. If you are using a desktop computer, you might need to repair your labview installation or reinstall Labview or the Labview real time engine.
The problem is I have been using network streams just 20 minutes ago and now it is telling me I need to reinstall LabView. Anybody seen this error before?
Setup:
-cRIO 9012
-NI Module NI9802
-Labview 2017
Thanks for your help.
(3,154 Views)
Accepted by topic author MikeIsMyName
Have you seen this article?
Error -314000
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OsOSAU
Anson K
Applications Engineering
(3,118 Views)
