Netscanner 9116+LabVIEW
unfortunately I can just saved for this version : 9.0, 8.6, 8.5, 8.2 and 8.0.
Maybe you can download the new version for the students?
Kind regards,Tom
Message 11 of 15
(2,545 Views)
Hi MicUser and Wuja,
there is a dedicated DownConvert thread available...
Message 12 of 15
(2,541 Views)
Hallo,
here you've another Screenshot from Programm just for NetScanner 9116 (Pressure) and 9046 ( Temperature).
Kind regards,Tom
Message 13 of 15
(2,540 Views)
Hi Tom,
 Can you correct this vi since I couldnot able to write the data file.  But I could able to read the data in front panel
Thanks in advance
Message 14 of 15
(2,519 Views)
Hi MicUser,
all you write in the file is the current time. Even better: after writing a string to a binary file (why don't you use WriteToTextfile?) you set the filesize (?) back to zero and so overwrite the file in the next iteration...
- You only show the measurement data in the indicators, there is no indication of transferring that data to the file write loop...
- Two of the loops will run forever, while the 3rd one has a stop condition wired?
- The sequence structure is unneccessary...
Message 15 of 15
(2,514 Views)
