Network Datastreams and FIFO Shared Variables
Does someone know why one would use a Network Datastream as opposed to a network published shared variable with FIFO enabled? Seems like they would be identical except that the Shared variable could potentially have multiple listeners.
Craig
(2,747 Views)
Hey Craige
You are correct that a major difference between Network Steams and Network Published Shared Variables with RT FIFO enabled is that the Shared Variable can publish to many computers at once.  There are a few other differences that are outlined in the comparison table in this article
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/network-the-user-interface-real-t...
There's another good comparison with some more information in the last paragraph of this article.
https://www.ni.com/docs/en-US/bundle/labview/page/streaming-data-and-sending-commands-between-applic...
Eric L.
Applications Engineering Specialist
(2,739 Views)
