Network-Published Shared variable access
How can I deny the writing access to a network-published shared variable from all the network machines, except the machine where the vaiable was deploied??
(4,168 Views)
If on the shared variable security proprieties i add the host "*" with unspecified Write Permission, all computers should not get to write in the variable.
But it is not that that happens, all get to write. It´s this normaly?? So how can i solve the issue?
(4,142 Views)
so?
no answers?
nobody uses shared vaiables?
or nobody uses security configurations??
I'm wait for replyes...... Smiley Sad
(4,131 Views)
Hi Idilio,
Which version of LabVIEW do you use? Do you use DSC? Where precisely do you specify your security options?
Cordially,
(4,087 Views)
