Network Shared Variable Spurious Trigger
I am Having a NI-sbRIO 9607, where the control application is residing,
There is an Application of the a Windows based Host PC with LabVIEW runtime.
The Host PC application access the RT application's control using Network shared variable.
The Incident Happened there is a Boolean command which got triggered in the RT application without any user Input.
verified all components in the Network shared variable library couldn't find any redundant function.
Pl. help me out as this is part of a safety critical system.
(1,182 Views)
So are you saying that the embedded code updated a shared variable? Have you tried finding the part of the code that does it?
(Sorry, I don't understand what you "verified" and what you mean by a redundant function. Please clarify. Thanks!)
(1,150 Views)
