Network Stream (Write Single Element to Stream) Error
The Stream connection between Target (cRIO) and Host (PC) is True, but still the Write Single Element to Stream sometimes doesn't work after long time of cRIO inactivity. Can't understand the reason why the stream doesn't work.
I tried following things:
1. restarting the cRIO,
2. increasing the timeout,
3. restarting my application
Still the problem occurs frequently. Any guesses what might be the problem.
Thanks in advance!
(1,794 Views)
Even I got the same error. The Stream connection between Target and Host was True, but still the Write Single Element to Stream didn't work. Can't understand the reason why the stream didn't work. I tried restarting the cRIO, it still didn't work.
(1,756 Views)
