Network Stream is not working after building Exe (Executable)
Hello All,
I am trying to send data from one PC to another using a network stream method.
I took references from a sample network stream example for this implementation.
I mentioned the proper IP address in Host Vi.
I created two executables, one for the host and one for the target, and placed them on their respective PCs.
But when I run them, it gets stuck, and nothing happens next; I have to abort them forcefully.
Is there any firewall setting or any other setting while creating exe?
If anyone has any ideas, it will be helpful to me.
(1,710 Views)
Can you ping the other device? My LabVIEW used unintentionally a virtual HyperV network card. LabVIEW chooses network card by the the IP address. Can you turn your firewalls off and check if it works? If yes, add a rule targeting your build .exe for incoming and putgoing connections.
CLA
(1,680 Views)
