Network setting in Remote Panel Control
Is there a standard way to do the Network setting when doing the Remote Control? Customers have been asking how to tell the MIS to do the firewall setting, cause once the firewall doesn't setup well, the Remote Panel will not work properly and will have some failure messsages. Looking forward to hearing the feedback as soon as possible.
(2,646 Views)
I imagine if you have a firewall, you want to know what ports are opened when you connect to a remote front panel. I know that port 80 has to be open but I am not sure about additional ports. There are programs on the web that will allow you to monitor port activities. Look for portmon and/or netstat .
(2,646 Views)
